got me whipped but not for long
2.1K views 31 replies 7 participants last post by  carolina jim
#1 ·
Craftsman 917.2273394
New battery, new starter, new solenoid, all safety switches check as good.
Has 12 volts at the solenoid on white wire when switch is in start position. All cables have been checked and cleaned.
Solenoid will not engage. Bench tested and was good.
Please, What am I missing?
#3 ·
Make sure the solenoid has a good ground, also make sure the battery ground wire has a good, clean connection. One possible way to check the ground on the solenoid is to meter the case of it, assuming that it's metal, while having voltage on the input wire. Voltage on the case means it's not grounded. Or just check the resistance from the case to the batter negative terminal.
ETA: If the solenoid has a second primary terminal, make sure it is grounded, since the solenoid probably doesn't ground through its case.
  • Like
Reactions: JP Savage
#4 ·
I do have voltage on the battery cable to solenoid terminal. I have a 4 terminal solenoid and good ground on the connection. I have continuity between the the 2 small terminals on the tractor or on the bench,
What seems funny is the starter showed continuity between hot post and case, and that is why I got new starter. The new one has this same trait and so does my other tractor. Why would this not indicate a starter shorted to ground?
While waiting, I disconnected all safety switches and bypassed them. checked continuity on all wires in harness and found no problems,
#15 ·
You start with a four pin 12V relay...30 or 40 AMP for horns and lights ...available for as little as $3.50...I have seen for as much as $11...any auto parts store
2457458
you will also need an in line fuse holder with a 30 or 40 AMP fuse....a few pieces of wire and a couple of soldrless crimp terminals....then just wire it in according to the attached sketch.....the numbers that you see do not mean anything to you right now...but you will see those numbers on the relay...if you have any questions just ask...if I don't answer right away you can PM me and I will get an email letting me know
2457459
...Brad also made this video
#19 ·
The starter shows continuity to ground because that is the circuit - in other words, the current goes into the starter, through the armature, and returns to ground via the starter's case. Quite normal.
The starter likely has permanent magnets under the "skin" that act as the field for the armature, hence the magnetism. One good reason not to hit the starter with a hammer. The magnets are brittle, and will break, becoming useless.
I don't remember if you actually have 12 volts on the solenoid terminal. If not, then you may need the relay mentioned, or have a bad switch.
If you have 12 volts to the solenoid coil, a good ground, and a good solenoid, it should pull in. One of these three things is missing.
#23 ·
If wired correctly the safeties should still be in the circuit that uses the additional relay. If there is any problem with them the relay that you are adding may not get energized (just like starter solenoid wasn't). I once had a no close solenoid (new one acted same). I had the 12v on the white wire but there was not sufficient current passing along with the voltage. In my case it was a bad internal connection from B term to S terminal of the keyswitch.
Adding the relay may work because it may take less current to close than the starter solenoid.
#24 ·
UPDATE:
Added relay and ended up with same problem. Went over wiring again, reinstalled relay. now have solenoid clicking in but no power to starter. Wire from switch to solenoid has full 12 volts.
Remove relay and rechecked wiring on tractor.All checks good. Reinstalled relay, solenoid still clicks but no power to starter. Got to be a Gremlin somewhere. Jumper wire from positive battery cable to small terminal on solenoid and it kicks right in.Retest ignition switch and it still checks good. Put it back on and everything works properly----? It's working right now so I am going to leave it alone and see how long it works. Thanks guys.
#26 ·
Have a question related to all this. Have a similar tractor Sears GT/18 917.257061. Can't start it either. Looking to figure out where the safety switches are that are mentioned in the manual. You said that you bypassed them and I saw someone else mention that they cleaned them. Can you give me direction or a picture as to where to locate them on the tractor? I would suspect they would be in a similar location to yours. Any help would be appreciated!!!
#29 ·
Common areas for safety switches that may need cleaning or tighening of loose connections(that I know of) are:
-under the operator seat, spring loaded to show presence/absence of driver
-at the pivot end of the 'engage' lever for the mowing deck
-operated by the brake/clutch pedal mechanism
First will kill the engine when no one is in the seat EXCEPT if the parking brake is applied AND the engage lever has been disengaged.
IOW, no running with the seat empty and the blades engaged
Third will disable the starter, preventing the engine from starting unless the pedal is depressed(and held).
I think the starter may also be disabled if the PTO(blade) is engaged.
Obviously you will have to figure out what you have and where it is located. The switches are there for good reason, and should not really be bypassed as what YOU know about your mower, "That NO ONE ELSE will ever operate..." will not be known by someone besides yourself who eventually WILL operate... Murphy was an optimist, Stuff Happens, etc etc etc.
If you don't have a copy of the owners manual, you should be able to find a manual in PDF format that is very close(very similar model numbers) that describes the switches and the schematic.
tom
#30 ·
If you have 12 volt to the S terminal of the starter, have bench tested the starter all should be well BUT have you checked for the battery ground to the starter? Remember a starter needs a complete circuit to operate. The starter is a high load on the electrical system although the carb solenoid may work a poor connection may not allow the starter to function.
