Hi all, I recently purchased a 641 work master from my father in law. I was bushhogging with it and noticed when I pulled the lever up to raise the 3 PH the bushhog trailing wheel just barely clears the ground. I found the selector lever under the seat to change from draft to position. My question is does the lever turn full 90° from horizontal to vertical and lock in? It stops about 85° and hits spring pressure. If I hold it back against the spring pressure the lift arms go all the way up but as soon as I release the lever it drops back down to just above the ground. Thanks!
