Finally pulled the trigger and got myself one...
1 reading
3.6K views 6 replies 4 participants last post by  AYP123
#1 ·
Well, my friends, I finally convinced my wife to let me get a tractor. We bought a house a year ago and, while our lot is only a quarter acre, we have plans on growing our real estate portfolio greatly. Anyway, I found a craftsman tractor that has seen better days, but it runs great, starts right up (even when cold), and included a few neat accessories to sweeten the pot. I got the tractor with a Craftsman brand: 46" cutting deck with 3 bag hard sided bagger, snow plow, and tire chains, as well as a Brinley brand 48" core aerator for a total of 550 dollars.
The only complaint I have is that the paint is pretty worn, but the tractor was stored indoors, so rust is minimal. When I bought the tractor it had the classic worn steering gear, so it could only turn right, but I replaced that already.
All in all, I'm into this bad boy for 585 dollars, including the steering gear repair.
The tractor is a 917.273070 with a 22hp Vtwin Kohler engine with the manual 6 speed (plus 2 speed reverse) gearbox. Here's the thing: I can't find out what this thing's capabilities are! Any ideas? I am wondering what year it is, and I'm looking for a classification for it. I mean, is this a lawn tractor? Or a garden tractor? Would I be able to put a box scraper on it? Or a pull behind plow? What kind of power output can I expect? If I can use some more power intensive attachments, where can I get the sleeve hitch required?
Thanks in advance for your responses! I'll be sure to get some photos up tomorrow morning.
#2 · (Edited)
#3 ·
I appreciate the response! I did find those two resources, but unfortunately, neither of them have the information I'm looking for! I have, however, figured out that the GT stands for garden tractor and that it is from the year 2000. So that puts me in the right direction.
#4 ·
Being a GT does imply you can do more with it vs a lawn tractor. The capability of these small wonders comes down mainly to weight and traction. Put on some water-filled and/or weighted rims plus some tractor tires (something more aggressive than turf tires), slip it in low gear and you might do pretty well pulling a single bottom plow. You might do even better with a box blade or rear blade....unless you get one with rippers.
Whatever horsepower the sticker on the engine says isn't nearly as important as torque and weight. My 12hp Sears Suburban is a beast pulling the plow. You'll just have to learn as you go, but you will definitely be able to some some limited ground engagement. Just keep your expectations realistic.
The next thing you'll want to find is a rear 3-point or a sleeve hitch. Google those for your machine. An electric one has the cool factor, but manual works just fine. Then you can start getting your box blade, plow and even a tiller.
  • Like
Reactions: Mrwiggles2
#7 ·
That's a really nice mower. It's basically bulletproof if you treat them right. Looks like it has a Peerless 6 speed with the Hi/Lo range. Great for pulling implements or uphills or both! My guess is it's a CV675 Kohler on it? Very reliable engines. Keep the oil changed and you can probably get to 1000 hours on that machine easy. Even the ones with the hydro can go that far. I saw one of those exact mowers with 1500 before. The Kohler Command is a beast though, I have one on my 02 DLT 2000 that's burning oil and fouling plugs every few hours but I still haven't given up on it. It's been 90hrs I've been running it like that. Looks like you go a very good deal there with all those attachments too.
