Throughout the Spring and Summer I have been mowing my lawn with the 48" deck set high (3.5") on my John Deere X500. My plan today was to lower the deck and cut the grass short to prep for fertilizing and possible reseeding.
When I went to lower the deck, I first adjusted the height adjustment knob to 2" with the deck in the raised position. I then released the deck lock and expected the deck to go down, but it did not move much lower than what it was set at originally. I also expected the pedal to come up as the deck lowered, but it stayed down as well.
I attempted to look under the tractor to try and determine the cause of the problem, but the deck was blocking almost all visibility. It was at this point I decided to try to take the deck off. The operator's manual states you are supposed to pull up on the deck lift pedal and lock it in place before removing the deck. When I attempted to pull up on the pedal, I found it to move very little. It seems that something may be blocking the pedal or deck movement, but I don't know what it would be.
Has anyone out there in the MyTractorForum community experienced this problem with their deck? I would appreciate any insight / advice on troubleshooting this issue with my tractor. Thanks!
