I'll try to keep this thread updated as I go along, but I'm a complete noob so expect some setbacks as things progress!
I bought this tractor early this year, I needed something to mow several acres of grass every week, so I intended to really use it from the get go. Bought it from a local seller for $500 bucks, just needed a battery and it ran fantastic. Of course, as soon as I got it home and off the trailer, it started smoking a bit and had a fair amount of blow-by.
Just got it home:
I changed the oil and put in a new battery, then used it to cut grass for a few weeks and adding nearly .5 quart of oil each time. Eventually I removed the deck to sharpen the blades and replace a wheel when it broke. I also replaced the starter generator belt since it was about to break.
Fooling around with the deck off:
Wheel that caused the deck removal, and it's replacement with a grease-able metal hub (later cleaned and painted) :
So I put the deck back on and used it several more weeks without issue, other than the oil consumption. This old tractor really impressed me, it had no trouble cutting tall grass even if it was as high as the hood.
...And then this last weekend came along. Out of nowhere the motor just stalled and there was one heck of a backfire as it quit. Motor turns right over like there is little to no compression. I was planning on a full rebuild of the engine this winter, but that got pushed forward to now.
Just got it home:
