Kohler HH70-140054c ser 0119d gas engine. Getting no spark to the plug. Used to run good but let it sit a few years now no spark. Does have electric start.
I cleaned everything best I could and see. Checked switch, assume all is good, turns over starter OK.
My question it's a three wire switch. 1)Hot, 2)switch keyed power to starter solenoid all OK. 3)Then there is a black wire that goes under the flywheel but stops by the carb. linkage so when the throttle is pushed in it grounds out. Is this supposed to be grounded all the time? I get continuity from at both spots, even tried to disconnect it from going under the flywheel.
Any help would be appreciated!?!?!?
