Greetings, I am new to the forum. I have a 2001 Kubota B21 and the bucket rotation cylinder (ram) is leaking. I need to dismantle the ram and put new "O" rings in it. I havent been able to find an adjustabel pin spanner wrench to fit the cylinder. The cylinder diameter is approx 2.5 inches, the hole for the pin is 11/64" and the depth is about 3/16". I called Kubota service in Calif - No Help. I have searched the web and cannot locate an adjustable spanner with these spec's. The manual says to use an adjustable Gland wrench, but I believe these are used on the larger cylinders as the pin holes on the smaller cylinder are on the circumference of the cylinder. I guess I could use a pipe wrench, but I sure hate to. Any help would be appreciated.
