Add Hydraulic connection to JD 1130?
2.1K views 8 replies 4 participants last post by  Zebra5
#1 ·
I have a 1976ish JD 1130 3cyl diesel tractor. Runs great. I'm adding a front end loader and need a hydraulic connection for it. I've looked at my service manual for other variations on this tractor that had hydraulic ports and its not real clear what I need to do.
Basically my understanding is I need to tee into the pressure line coming from the pump to the transmission, but what about the return? Just find a spot that dumps back into the transmission?
I know several other modrla of JD are similar to this one, like the 830 and 1530, but that question still isn't answered.
T.I.A.
Curtis
Sent from my hammer and chisel using Tapatalk
#6 ·
The pressure line is 1/2" or JIC-8 Rather than use the parts JD shows get a -8 JIC swivel TEE. Male/Female swivel on the run, male on the branch for your loader valve hose.
The ported cover inlet will be ORB SAE-12 to JIC -10, then the TEE drops from JIC-10 to JIC -8 at the branch for the hose. Only reason you need a TEE at the filter cover is if you have something else returning there too. MY SCVs also return to the fitler cover.
#8 ·
Got my fittings, filter cover, tee for pressure side. Now I need hoses and the quick connect fittings to hook up to the loader.
Should I add a hydraulic fluid cooler to the return line near the radiator?
Tractor has the blank panel on right side where factory cooler goes, just not sure if I need one. I'm thinking yes as driving more cylinders will create more heat that needs to be removed from the fluid as I work the loader on it.
