I picked up a 4 Cycle Trimmer trimmer, added new oil, replaced the broken prime bulb, and cleaned the carburetor.
When I pull the string it's leaking oil out the side from the air cleaner. It doesn't start.
What should I check next? Could the diaphragms be the problem?
Update - the spark plug has a spark. It wasn't plugged in all the way. After I plugged it in tightly, the engine started but died right away. I think I am almost there. Just need a few pointers. May be there's not enough fuel in the engine.? I removed the returned fuel line and I see fuel come out of it when I pressed the primer.
