My 1999 JD 345 Kawasaki 20 hp water cooled FD611V-BSO1 code engine is giving me some troubles. It started this "surging" at idle rpms, and seems to have a little "missing" also. I have removed the carburetor and removes all parts...jets, main jet, nozzle, and main nozzle, both air jets, pilot jet...Soaked in carb. cleaner over night, and air blown all parts. Installed new carb . kit (sold by JD dealer.) Installed new gaskets on carb/intake side, and air intake gaskets. New s. plugs, new fuel filter, and new spring from governor/control bracket. Removed seat, rear fender, and removed gas tank, and cleaned it out. Also installed new fuel hose from tank to carb. and fuel pump.
Also adjusted the governor arm on the governor rod by putting a allen wrench in the end of governor rod and moving the rod full counter clock-wise with high speed throttle in fast position. Also adjusted the intake and exhaust vales to 0.010 at cold settings.
The results: Some (most) of the surging is gone, but there is a "miss" in the engine at idle and fast speed. It also will die (shut off) sometimes when at med, low idle range.
Anyone have the cure to this problem?
