12sb mikuni vs. walbro ?
2.8K views 12 replies 3 participants last post by  lawnboy dan
#1 ·
Hey guys. I'm new here so be easy on me! lol.. Here's the problem. I just picked up a JD 12sb with the briggs 2 stroke and a mikuni carb. Cleaned it all up and it ran great...for about ten minutes, then it just died. Well I pulled the plug and it was soaked. Wiped it clean and after a few pulls it fired right up but then died about 30 secs later... I replaced the plug and got the same results..good spark but lots of fuel on the plug. I pulled the carb and checked the float , all seemed well in there but once I put it back together I still couldn't get it to stay running. Kind of lost here but I've read in the past about swapping the mikuni for a walbro...Where can I find a walbro for this engine? Any help would be greatly appreciated as I really like this mower but I'd like it alot better if it would stay running! lol
Thanks, Mike.
#2 ·
Did you check the enrichment adjustment on the mikuni. I want to say that it's one and a half turns from full closed. Make sure yours isn't WAY rich (too many turns out from full in).
#3 ·
there is no adjustment on this mikuni carb. the best way is to get the john deere part # for the walbro and buy a new one. it will take some doing to figure the part # the later 12sb ser # will be the walbro carb and the early will be mikuni. if i get time -i might look it up for you . a new one will be your only option. forget about any help from briggs. they quit supporting this engine 20 years ago. its really a japanese engine imported and sold by briggs foe only a few years
#4 ·
You're right, Dan..... Zero adjustments on the carb other than one for the idle. I took it off again today and cleaned everything on it and in it with carb cleaner ...Couldn't even get it to pop today.. Spark plug still has a nice big spark and it's getting plenty of fresh fuel so I am stumped.
Dan, when ever you get a chance if you could get me that walbro part # or can point me in the right direction that'd be greatly appreciated! :trink39:
Thanks again.
#6 ·
sometimes a mikuni just cant be fixed with a cleaning. i have the briggs "factory" manual for the briggs 2 stroke (quite rare!) and its states the walbro and mikuni are interchanageable but dosnt go further. i have never tried this myself and would hope you dont need any linkage changes. i have both jd 12sb versions and will look into this as it would be a good thing to know . lucky my mikuni version is working fine-but i have had nothing but probs with all 4 past versions of this engine /mikuni. the 12sb when working is an awesume machine. after all a 2 stroke version of the 14sb can only be a good thing! the info for the carb part # is on the john deere parts look up site-but it takes a lot of digging to find as its not very user friendly
#12 ·
I am scared to hear how much that will be...:Stop:
