1025R question
11K views 21 replies 7 participants last post by  MI GT
#1 ·
For you 1025 owners, is there a cooling fan for the transmission or does it have an oil cooler near the radiator as the 748 does?
I am considering trading my beloved X748 because I don't want to keep replacing radiators every 150 hours. I have some rough terrain and it seems the frame twisting is killing the seal in the radiator pan.
I am considering a 1025R or Kubota BX. One downside to the BX is the cooling fan that tends to damage easily and is near impossible to replace. If the 1025 has no fan that is a big plus.
I plowed snow this morning and at near 0 degrees and the radiator is puking pretty good. So far this season it has been just dripping a bit. It is now worse. In summer it may be better. If it starts to leak pretty bad in summer like the last one it is getting traded.
As much as I love this tractor at 375 hours it has needed two radiators and a water pump. I am no longer willing to live with this level of unreliability.
One alternative I am going to check on is an heavy duty radiator or possibly mounting it so it floats and does not flex with the frame.
This tractor should have been painted mostly yellow with green wheels.
Discussion starter · #5 ·
The hydraulic cooler on the 1025 is in front of the radiator, like it is on the 4010. There is no hydraulic cooling fan to get ripped away by brush like on the 2210/2305 and Kubota BX brands.
Thanks. That is good news. Gives the 1025 a big advantage over a BX in my thinking.
Discussion starter · #15 ·
First, the oil cooler does not have plastic pans clamped onto it so it should be very much more reliable. I prefer that to a fan. The cooler on my X748 is fine. I wish I could get an engine radiator without the plastic crap.
According to the JD web page the 1023 does not list cruise control. That is a feature I want.
Discussion starter · #21 ·
I am going to give my X748 one more chance. In looking at the radiator mounting I have an idea.
I am going to drill out the lower two mounting holes and then use a thin spacer on the bolts. I will design it to have about .050" movement along the longitudinal axis of the bolt and about 0.100" axial movement.
This will, I think, keep most of the frame twisting from transmitting the force to the radiator.
It's worth one more shot at fixing it. I really would love to keep the X748. It is a great machine for what I use it for. I like not have a ROPS for mowing around trees.
If I go to a different tractor than I also have to design and build a new platform for my ULV sprayer. So some extra work in trying to fix the radiator issue is probably well worth trying.
