JD 2305 Rear Wheel Spacer Install Part #1
John Deere 2305 Rear Wheel Spacer Installation:
The following pics are of the wheel spacer kit being installed on my John Deere 2305. These spacers are sold for the X729 and X749 Ultimate Tractors but also fit the JD 2305. My unit has the 260 Backhoe so I do have issues with tire chains rubbing on the backhoe frame mounting bolts. This not only will alleviate the clearance problem for the chains but will also add extra stability providing a wider rear footprint. Others on MTF are already running these spacers with positive results. The installation was simple and straightforward. The two spacer kit (#BM22725) with bolts cost me $128.00 from my local John Deere dealer.
