Where can I find Ag tires (or any tires?) for the Ingersoll 4020 (32x8.00-16)
I can't find them anywhere?
Thanks...I have checked every way I can think (tractor and garden) and nothing comes up in the size I need...I think you can find is look for tractor tires instead garden tractor because they are limit to 26 size but tractor tires is big.
You could ask Ingersoll 444 he did have ag tires on his Ingersoll 400 series or 4000 series.
Thats a good point. Now I have TONS of room on mine with the 44" and 48" deck. Not sure how tight the 60" deck fits in there.Don't forget about hitting the deck.
To be honest...it is a loittle tight with the 60" deck...that might be an issue. But at the same time...now that I have everything aadjusted the way I like...there seems to be more clearance than when I originally picked it up. We'll have to see, I guess...although I can not afford to be buying tires just to "check" if they work, you know?Thats a good point. Now I have TONS of room on mine with the 44" and 48" deck. Not sure how tight the 60" deck fits in there.
Then buy yourself a dressmakers tape and then jack one wheel in the air and take a circumference measurement. Whatever tire you are looking at can be measured the same way by the party trying to sell it to you for comparison purposes....although I can not afford to be buying tires just to "check" if they work, you know?
