Stinky exhaust from your Kawi riccocheting off your front tire making you sick? Well folks, gag no more! Using 1 1/4" chromed brass sink traps you too can make a nifty muffler extension that gets all the hot gasses (engine gasses only) away from your right front wheel.
Remove the expanded section of "J" bend to reduce diameter of pipe to 1 1/8", slip over current muffler outlet "stub". Allowing for front axle upward movement and wheel steering angle for left turns mark outside of bend. Cut chrome pipe in a neat scarfed angle, clean up rough edges. Cut four (4) 3/4" long slits for clamping in muffler end of extension. Install on muffler with "Made in U.S.A." stainless worm gear clamp.
Enjoy cleaner air and classy look all in one half hour of pleasant home fabricated tractor modification.
