21 - 34 of 34 Posts
Sure do. 1972 110 JD. Haven't started it up in a week or so...Ill have to go start it up and run it a little bit tomorrow now. Been pretty busy. Dad has the first one I ever rode one. JD 160 (Is it bad that I ran a farm tractor before a garden tractor?)
When I built my house in 1976 I wanted a garden tractor with shaft drive. I was thinking of a Bolens or Dayton (MTD 990). I was able to get the Dayton for less money. I never regretted my choice. The tractor is over 30 years old and I still use it around the house more as a work tractor rather than a mower. Now that I have made a FEL I plan on a lot more work years out of it.
Still have mine 1994 416-Hydro. Just started collecting implements for it. Last year I got it a plow and a 414-8, and this year a Snow Blower and soon a C-Series.
Bought a new A NEW BOLENS 850 41 years and 1 month ago.
Got a dirt blade , rear tiller and 38'' deck with it. Deck quit about 12 years ago.
Put the blade on it in 2005 and just leave it there for pushing dirt snow etc.
Put the tiller on a 1967 Bolens 850 just like it that i got 6/2005 .The tiller stays on the tractor.Have the 38'' deck that came with the 67 .Works on either Bolens.
I'm lucky enough to have bought the farm I grew up on. Before I bought it my wife and I had lived in a subdivision with a only 1/2 acre so when we moved into the new/old place I had nothing but an 11hp Murray with 36" deck and I quickly learned that it would take about 5 days a week to keep it mowed.
Dad was nice enough to throw in his old Dexta with the house so I could at least bush hog the 5acre part that is usually finish mowed instead of using my Murray.
This is the same Dexta that I rode on the fender when I was 2 years old while dad disked the burley patch and the same Dexta that I ran over my sisters leg with when I was 8 yrs old :fing20: (it was muddy and she was fine). The same Dexta that I smashed into a tree when I was 12 because I had never been down a hill before and thought the clutch is what stopped it:swow: .
To me it's priceless even though it doesn't look like much, but every time I fire ole Blue up it brings back some of the best memories.
So yeah, In a way I guess you could say I still have my first tractor.
Great topic...
No I do not have my 1st mower. It did serve me well though. I used the 1972 Sears LT10 w/ briggs to mow and clear the 2 acre lot that I had purchased back then. I was so poor that I could not afford to change the oil or spark plug. I wore the deck linkage out so bad that it would sag down badly in the front and wear out the engine to deck belt. As I recall, it was quite a magical trick to weave the belt around the shifter to install the new one. I drilled four holes in the deck and tractors underframe, installed four carriage bolts w/ washers about 8"s long. This kept the deck level but only at that height. I never had to replace the deck belt again. I gave that old warrior to my brother in law when I purchased the new 1986 Wheel Horse, which I am now making a pulling tractor out of. That Wheel Horse is as good today as the day that I purchased it. The 42 s/d deck looks like it is only a few years old. I must admit that the baffles underside need work. The paint on the older Wheel Horses was also much better than that of the Toros. My paint is original and still looks terriffic. Kenny Britton / oldchurch
I still have my first Lawn Tractor and it still does all the mowing. It must be close to 20 years old now, it's a Cub Cadet LT1320.
I don't have my first tractor.... it was an old mid 70's Ford that I bought for a hundred bucks... the paint was bad so I painted it white with two grey stripes like a shelby...LOL
I built a snow plow for it...and boy did it plow.... it died a horrible death when the brass bearing I installed the rear axle seized to the case and snapped it in half...
I pieced it out and that's it... great little 10hp tractor...
The first new one is my 2006 cookie cutter MTD lawn tractor... still looks like the day I bought it... but the 1973 Wheelhorse I just finished restoring will go to the grave with me...
Well my first tractor was not a Wheel Horse it was a 1963 Bolens model 600. I used the Bolens every week to cut lawns and in the winter a home made snow plow was used that my grandfather built. This Bolens is the reason I own Wheel Horses , not because a Bolens is not a good brand they are a great tractor. When I bought my house I remembered the Bolens and how tough it was with the cast iron front end and tough transmission, I knew I needed a tractor that would built like the Bolens and found that Wheel Horse with had similar quailties. In 2004 I bought my parents a Wheel Horse model B-80 to replace the aging Bolens (I was hard on the Bolens) and traded the Bolens to Ray's Mower Shop in Boyertown, Pa. for some Wheel Horse parts. Over the years the Bolens recived a paint job which was not factory colors, a battery box welded to the rear to hold a car battery, the 6hp briggs was changed for a new 8hp Briggs engine, a car head light was welded to the hood and a racing aluminum "T" handle gear shift knob I made in shop class. With the "T" handle shifter I made a lot of passes down the drag strip on the front lawn banging every gear!
The Bolens is still up in Boyertown at Ray's and I hope some person buys the tractor for a restoration or parts ..... it deserves it!
Bill in Richmond, Va.
Bill... My shopping was along the same lines as you. Used old JD 110, and a 112 for years growing up. I know they were tough, and built to last.[still have the 112] so when I went looking for a mower for my land I bought in 2000, I was looking for a JD. Well wile shopping, I ran across a tractor I had never heard of before. All I knew about it was how tough it was built. All steel, and cast iron. Well that tractor did not fallow me home,[though I DID end up with the one that was next to it in line. Just picked it up last year for parts:D] but I found what I wanted, and have been a big fan of the Ingersoll tractors ever sence.
I do. In 1987 my father brought this Wheel Horse 1056 home in pieces after getting it for $25. He put it together and we used it up until 2005, when the transaxle let go. By that time she had plowed 4 different driveways during the WNY winters, mowed 5 lawns in the summers and hauled 30 or so cords of wood out of the woods every fall. We still have her and hopefully this winter she will see a full restoration. I'm thinking he got his money worth, and she deserves the attention. This was taken in December of '04 about 2 months before "the incident". I was the first person to start it once he got it back together, (I was 4) and I was on it when the transaxle came apart.
Nope--it was an old Sears 80's model w/ 10 hp Briggs. About four years of cutting/mulching/chopping up small stuff did her in....
Got a couple old W/Horse's now and a Cub that'll probebly outlive me...:biglaugh:
21 - 34 of 34 Posts
