21 - 39 of 39 Posts
I'm sorry, I'm just not seeing where that's all that bad. Looks fine to me.
Your loader would hardly move with the 15 YB. I think the 15 is 1.5 GPM and the 58 is 5.8 GPM
Discussion starter · #28 ·
well I started to change the belt and order a new tension kit from the guy in Texas. So I hope after it is all done it would be better. Thinking of replacing the pump too anybody can tell me what pump will work.
I bought 2 belts from napa...Thanks for the info
Did you buy the green belt? If not, take them back and ask for the same belt with a "W" on the end. You'll be glad you did!:fing32:
Is your pump not working? If it's working, why replace it?
Well yesterday I had the loader with some wood and it din't raise so I am hoping that the new belt will help but always ready for the worst.
And if I have the 15yb and not the 58yb pump
It didn't raise because you have the link belt on there and it's not tight enough. I went through the link belt thing with mine and I will never put another on a loader tractor. Get them tight, they stretch and eventually break. Mine lasted 6 months. The green belts will help. That's what I'm running now. Make sure the pulley on the pump is tight too. Been there, done that. Once you get the belts on tight and know that everything else is tight, then give it a try. Bet you will see a big difference. Remember, when it's cold out, your hydraulics are going to move slow until they get warmed up. I doubt you have a 15yb pump. The new belts will tell the story. Once on and tight, your three point should raise very quickly. I always tell people that I think I could throw the counterweight up and over my head it raises so fast. Before you go thinking pump, try the small stuff.
My old belt was slipping badly. It's the one I replaced in my belt chamging procedure thread. Between the belt slipping and cold oil, I had a heck of a time using the loader last winter but it did work some. Change the belt. It's not that hard a job and you can always change the pump later if you have too. The pics of your pump look like the bigger one to me.
21 - 39 of 39 Posts
