I'm working on my neighbors Troy Built lawn tractor, it has a kohler 23hp v twin on it. It had a problem starting, when you turn the key it would just click. Try a few more times and it would crank and start. I checked the battery and it holds a charge just fine, my charger has a diognostic function and the battery tested fine. Checked the charging system and it's just over 14 volts. I have a little more than 12 volts coming from the switch to the solenoid, same voltage at the solenoid from the battery. When it just clicked, I checked for voltage on the output terminal on the solenoid, going to the starter, and nothing. So I replaced the solenoid with a new one. Now it's doing the same thing. I removed the starter and cleaned the brushes and the armeture while I was waiting for the solenoid to arrive. I checked all the connections, everything is clean.
What am I missing?
What am I missing?
