41 - 60 of 62 Posts
Discussion starter · #41 ·
I had my brothers CUT here for a 7-10 day stay in early June, 11 weeks later it is going back . . . . without the FEL I just would not have done it . . . .
That is sooooooo true! If i didn't have the FEL, I would have spent the summer in house, in front of a computer, getting fat. So for all of you who are trying to justify buying a FEL -- you buy it for your health. Better than a treadmill! :thThumbsU
Wow!! That is quite a testimony.
I can hear it now: "Honey, do you really care about my health and fitness?"
:D
:D
I may be using this real soon!:fing32:
Discussion starter · #44 ·
:D
No fooling, it works! When I got back for Colorado I weighed 178. Today I weigh 169. So the FEL caused me to lose 9 pounds in 6 weeks. So you can tell your wife that. :thThumbsU
(Of course, working in 100 plus degree weather might have had something to do with it too :thSick:, but don’t tell her that!)
Roy, today I saw a twin to your tractor at my dealer waiting for delivery. It had the fel and 3ph and all the goodies. It was the first time I had seen one with a fel on it in person and man what a sweet set up! I can see why you have so much fun with yours. The added physical fitness benefits are a pretty sweet bonus too!
(Of course, working in 100 plus degree weather might have had something to do with it too , but don’t tell her that!)
BTW I would love to see 100 today take a look at the temp right now in the great white north.>>>
You know Roy.... You sure don't mess around!
***Jealous*** (in a good way!) :)
Discussion starter · #50 ·
Great that you got the stones for free. Those alone are pretty expensive where I live.
Yeah, that was a deal I couldn't turn down, even not knowing at the time what I would do with them. They are $120 a ton here, not counting delivery. I'm thinking I got 6-8 tons.
Funny how free stuff ends up costing quite a bit , those were really spendy bits of stone :biglaugh::hide:... Great job, and thanks for sharing the story Roy.
one word: BRRRRRRRRRRRRRRRRRRRRRRR!!!!!!!!!!!!!!!!!!!!1!
2. "Did you pack the dirt fill in the shed area, water soak settle it, or do anything else to it before the stuff/concrete went on?"
I didn't water soak it (probably should have, but water is hard to come by in this drought) but that road base gravel packs in tight. I did "dump and pack" several times by running BG back-and-forth over it, and then using a manual tamper (that was a workout). With the weights and full bucket, added to the weight of BG, I estimated I was about 2,500 lbs total as I run them AGs back and forth on top of it. :thThumbsU
Roy, you did this correctly..
When you add water to the dirt it causes the dirt to expand.. When you removed water from the dirt it will shrink. Sooo should anyone make a mud bath and tamp it to make a solid base? NO.. To get the densest ground you tamp/pack/vibrate dry dirt.
On the other hand, if you have ever experienced flooded ground you will know that when a large body of water "sits" on the ground it will cause compaction because of the weight of water (7lbs/gallon). This is why guys use rippers to aerate the soil and promote drainage/absorption.
If you wouldn't have tamped it as you piled the dirt, there would have been voids and "YES" as posted that would have been acceptable if you allowed it to dry out completely. If you use enough water you can get the dirt to "float" around and fill those voids by its weight, but getting back to my #1 point, it would have to completly dry out before you could build upon the ground because of shrinkage. This is why you don't want you house builder to dig a foundation right before a 2 week rainstorm then pour the foundation :)
Kind of make sense?
Discussion starter · #56 ·
Roy, do you mind me asking what you had into building your shed? Just in materials, not the cement floor.
The framing, decking and dry-in material cost $632 (note that I used 5 squares of shingle but only bought 1. I already had 4 squares and all the drip edge.) Hardi Plank siding and trim was $910. The Roll up door was $206 and the Front Door was $180. So total cost to this point was $2151 less the slab.
I could have used vinyl siding, no OSB decking on the walls and built it on 24 inch centers instead of 16 (like the kits are) and it would have been a lot cheaper. But with the Hardi Plank, I'll never have to paint it again and it’ll be there forever! Besides, nothing is too good for my Big Greene's house. :thThumbsU
Add all the plumbing, electrical, light fixtures, air line, pneumatic framing gun, pneumatic stapler and sink – and the total ends up at $3,500.
The slab was $1,100 so grand total ends up at $4,600.
In my neck of the woods, if I had hired that whole job out withthe same specs of material you used (plus hiring the labor) I feel VERY confident that $10,000 wouldn't have covered it. You got a first class building at an incredible bargain, because of your slavaged materials, the labor saved by your tractor, and the skills in your hands. In short, your tractor half paid for itself on this job, in my opinion.
Discussion starter · #59 ·
. . . In this case, the doing was likely more fun than paying someone to do it! . . .
You are so right! Beside getting it exactly as i want it, my son and son-in-law helped build it. It was great father-son time. :trink39:
24 inch centers instead of 16 :thSick:
Nice job and it will still be there for BG after a hurricane. :fing32:
41 - 60 of 62 Posts
