1 - 9 of 9 Posts
Danno77
Hi all, I just joined the forum and thought I'd introduce myself in the green area of the forum. I posted a couple of pictures in the intro section, but here's another one of the mower with the new tires I put on it this summer.
The tractor is a work horse. I do have a history, though, of doing things above and beyond what some equipment was intended to do. The LX hasn't minded. It doesn't know it isn't a bigger tractor, so Shhhh, let's not tell it.
The hood is cracked to heck, and the headlights were busted out so I replaced with fogs from wal-mart.
The engine is spectacular ONCE I GET IT RUNNING. that's probably the main reason I joined.
The problem is that I can't start in choke, I can only start in very low idle. If I try to throw it out of low idle right away it will die. If I VERY slowly raise the engine speed it will usually be ok. Sometimes jI can just walk away for a few minutes and let it run in that very low idle, then come back to it and rev it right up.
Once it's warmed up I can shut it off and turn it on without a problem. Engine runs great once I get it started. It has never "not started."
Had fuel lines and filter replaced right before I got ahold of it.
Where do i go next. Is this a float issue? some other carb setting issue?
Discussion starter · #2 ·
Here's another picture. This one is a load of hickory that well exceeded the 1000lb rating of the trailer (I'd guess close to 1500lbs). I don't do this every day with the LX188, but it's doing that sort of thing that will likely kill the hydro on it. I really need to get me something a little bigger...
Welcome to the Forum:MTF_wel:
Welcome to MTF and throw some SeaFoam in your gas and see if that helps. slkpk
Thanks for the welcomes!
Seafoam is SOP for all my engines, so that one is DONE. For kicks I even bought Marvel Mystery additive or whatever it's called. That didn't seem to do a thing for me.
All of my chainsaws run mix that has some seafoam in it, and every once in a while I add some to my car engines. I've never noticed a difference in my auto engines, but I do tend to have fewer fuel related issues with the 2cycle engines I run.
I really am thinking this is a float issue, too. I haven't even messed with the carb, so I suppose that will have to be added to the list of things to do this winter. The rider isn't used for snow removal (yet) so that's doable, i suppose.
1 - 9 of 9 Posts
