Hey everybody. I have a Cub Cadet xt1 lt46 enduro series that stopped working on me. For some reason the display shows low battery when trying to start and only clicks once at the starter solenoid but doesn't crank. The battery is good and has been load tested but when I turn the key, the voltage drops to around 8-10 volts but picks back up to 12.6-7 about 30 seconds after I stop turning the key. Could something be draining the battery that fast as to not start when turning the key or am I missing something else? Good battery, new carb, good spark plugs, and oil topped off. Any help appreciated.
