L LBRandy · Registered Joined Oct 28, 2023 · 2 Posts Discussion starter · #1 · Oct 28, 2023 Only show this user Can I use same solenoid for the JD Lawn tractor model D120 as the L120?
Brad · Premium Member Joined Dec 28, 2006 · 22,533 Posts #2 · Oct 29, 2023 Only show this user It does appear that they are the same. Did you compare the model number on solenoid?
L LBRandy · Registered Joined Oct 28, 2023 · 2 Posts Discussion starter · #3 · Oct 29, 2023 Only show this user Thanks for response, have not removed original as yet, will check
