Also I don't have a wrench to tighten this down, used channel locks as hard as I could.
No instructions or torque ratings. Actually there are instructions but Spanish only. Did see 217nm somewhere.
Edit - Wouldn't let me add any content...View attachment 2493945 Also I don't have a wrench to tighten this down, used channel locks as hard as I could. No instructions or torque ratings. Actually there are instructions but Spanish only. Did see 217nm somewhere. View attachment 2493946
Maybe he's in Australia, so it would be correct..........lolAbove the nut... which you have threaded on upside-down, turn it over.
You'll never get proper torque down with a pair of pliers, at least use a monkey wrench.
I always tell folks to just google the size bolt and torque. So, I just did "torque 1 inch bolt" first one that popped up was 622. I X'ed that one out and reworded it, and a chart from Bolt Depot popped up, it had a chart from a #4 up to 1 inch. A 1 in, grade 2, course thread said 180, fine thread 220. Over under grade 8, course was 660, and grade 8 fine was 7XX. I don't want to torque a grade 8 bolt on anything.160 ft. lbs. You aren't going to do that with channel locks.....![]()
Were you using a ball with the correct diameter shank for the hole in your hitch? I see a lot of folks using a ball with a shank too small for the hole in the hitch. 2-inch balls are available with 3/4, 1, and 1-1/4 diameter shanks.I have had one come loose, enough for the ball to shift back and forth to wear a groove in the bracket it bolts to. You need to get a socket to get that torqued down right, and perhaps, on an ongoing basis, look at the top of the ball around it's mounting surface when you hook/unhook a trailer, to see if there is any sign of the ball moving...
Ok I looked at that nut a few times. I just can’t tell what makes it upside down. Looks like the flats are almost identically radiused to both top and bottom of the nut. What am I missing?Above the nut... which you have threaded on upside-down, turn it over.
I am guessing that is because you normally put the washer UNDER the nut. So, clearly, the nut must be on upside down, but really it is the threaded shank that is upside down. But, it all depends on your perspective.Ok I looked at that nut a few times. I just can’t tell what makes it upside down. Looks like the flats are almost identically radiused to both top and bottom of the nut. What am I missing?
I'm pretty sure he meant the lock washer was upside down, not the nut. But, I don't think the washer is on wrong. As said but several, flatten that lock washer. Borrow an adjustable cresent wrench from the neighbor for about 20 seconds and offer to pull something for him some day.Ok I looked at that nut a few times. I just can’t tell what makes it upside down. Looks like the flats are almost identically radiused to both top and bottom of the nut. What am I missing?
