HI all,
This is on my 756 and I know wrong group but I think this could be a more generic question and apply to other Deere's so I am asking here.
With the tractor on/running the electro-magnet (yellow arrow) is supposed to be active so the PTO lever (blue arrow) can engage the PTO.
The part at the blue arrow is the PTO lever on the dash. The part at the yellow arrow is the magnet and the actual PTO linkage.
So, move the lever on the dash toward the front of the tractor and the part at blue arrow pulls the part at yellow arrow engaging the PTO. If a safety switch is activated then the magnet goes dead and the part at yellow arrow is released returning to the rear position shutting off the PTO.
Here is the issue!
The magnet isn't working when plugged into the wiring harness.
Test the plug on the wiring harness with magnet unplugged and key on and there is 12 volts.
Apply 12 volts to the lead from the magnet and it energizes and works correctly.
Plug the magnet lead into the wiring harness and with the key on you get NO voltage.
So, the magnet works with 12 volts applied via jumper wires but not when plugged to the wiring harness. It seems to kill the voltage at the harness.
Magnet show about 41 ohm resistance.
I tried messing with the seat switch and I can hear a relay like click when I push the switch so it seems to be working.
Any ideas?
I am thinking to just add a toggle switch and jumper to the magnet to energize it so it will work but really would like to understand what is going on and why the magnet kills the voltage at the harness.
Here is the issue!
Any ideas?
