I picked up a 1975 bobcat last week and after getting it running well and inspecting everything I proceeded to do a little work around the yard with it. Yesterday I worked the loader for about 30 minutes digging up and raking roots out of the ground with the teeth on the bucket. Well I parked the loader and went and got some oil and a new oil pressure gauge. I changed the oil, installed the gauge and then went to go do a little more work in the yard until i found that that hydraulics did not work anymore. I have spend 4-5 hours tinkering on this thing and I have yet to figure out what the issue is. I do have some hydraulic movement and it seem the pump is working as I can stall the engine by moving the hydraulics to their limits and holding them. The hydraulics are horribly sporadic moving quick but jumpy at times and then moving ultra slow at other times and even not moving at all without holding a pedal for a solid minute. I was told that the issue sounds like a stuck aux valve but I have wiggled the pedal and looked at the linkage and everything seems to be moving smoothly. Does anyone have experience with these older bobcat loaders?
Here is a video of me working the loader Monday for a bit. I Again everything seemed to work great or at least acceptable as far as hydraulic speed and power.
