My PTO solenoid was bad. When I would engage the PTO, it would blow a 25 amp fuse and I would loose all power. If I replaced the fuse, I had power and could start the tractor. Once I engaged the PTO, it would blow the fuse and I'd loose all power again.
If I replaced the fuse (under the dash) and disconnect the PTO solenoid, I could start the tractor and engage the PTO (with the solenoid disconnected, the deck doesn't engage) and not blow the fuse. This to be confirmed the PTO solenoid was bad. I replaced the solenoid and made sure I had a good fuse installed.
