Why Cast Iron Cookware
6.8K views 37 replies 21 participants last post by  loopyhomefabricator
#1 ·
Because Food Taste Better!
There are several reasons why many of us Tractor Enthusiast love Cast Iron cookware, many won't use anything else. Besides being an ideal heat conductor, cast iron heats evenly and consistently, is inexpensive, retains heat, and will last a lifetime with the proper care. There are some among us that are using cookware that is over 100 years old!
When seasoned, a cast iron pan will be stick resistant as good a Teflon! When you season cast iron, you are embedding grease in to the pores of the cookware. Without proper seasoning, cast iron will rust after coming in contact with water.
Season
Most people are not sure how to season cast iron (a lost art due to pulling it out of the box and start cooking mentality that we have grown to love).
To season your cookware, first warm your pot or skillet, then rub a thin layer of shortening or corn oil, or beacon grease (what are going to use that beacon grease for any way?) all over the surface of the pan, inside and out.
Lay the pan upside down inside a 350 degree oven, but I also found that an outdoor grill work great too. Most cookware manufacturers suggest heating the pan for one hour, while some cooks suggest up to 4-5 hours for just the right amount of seasoning.
The shortening, oil, or grease will turn is to a non-sticky, hard coating. Allow the pan to cool overnight as it will be quite hot.
Note: cast iron retains heat very well, so allow for ample cooling time. Some cooks recommend repeating this process one, or even two times, before using your cookware.
Using Your Cast Iron (Skillet)
Preheat your cookware before preparing your meal. Water droplets should sizzle, then roll and hop around the pan, when dropped on to the heated surface. If water disappears immediately after being dropped, the pan is too hot and will surely burn your food. If water only rests and bubbles, the pan is not quite hot enough.
Note: Dutch oven cooking most receipts will not require preheating.
Cleaning Cast Iron
You do not want to damage the season on the Cast Iron. Pour out as much of the contents, DO NOT Scrape it clean with any medal utensil! If you need to scrape it clean use a wood or bamboo utensil. Avoid using soap and water!
Heat up the cast iron to around 200 degrees F. Pour in (for a large pan or Dutch oven) 1/3 cup of cooking oil with a 1 tsp of salt. Swish it around with a wooden paddle. The salt collects everything, then scoop out the muck. Wipe it clean with cooking oil and a rag.
The residual heat will dry the light coating of oil.
The don’ts of Cast Iron
Do not pour significant amounts of cold liquid in to a hot skillet or pot; this can cause the cast iron to break.
Do not wash cast iron in the dishwasher, soak in water, or use strong detergents
Note: Acidic foods, such as tomatoes, can deteriorate the seasoned coating of your pots and pans
#2 ·
I got a ton of old cast iron cookware...from muffin pans all the way up to a 24" skillet and two dutch ovens. Some of mine is over 50 years old...we could'nt do without it...
Slam
#3 ·
We routinely wash the old cast skillets with the rest of the stuff. What harm does it do? I see no ill effect. Clue me in.
Mike
#4 ·
What will happen eventuality residual water is filling into the cast iron pores.
Worst case when the pan is heated the water expands breaks the pan.
Or water expands making hair-line fractures
Or oxidation forms under the seasoning and rust right through!
Or season is damage requires re-season
Or resdual detergent left in the pours leeches out on to the food when cooking! Yum Yum!
#5 ·
I love to cook, and have camped since I was a few years old. Seems like we always had something cooking in a pot of the fire. I have gone through lots of pots and pans, none of which impressed me, a few recent purchases were strictly what my wife wanted... Then you guys started on the grill, smoke and then Cast Iron cooking.... I started checking on the Internet and decided to pick up the Cast Iron Cooking for Dummies... (also recommended by DYT4000 here...). I had shopping to do, so I hit the book store first and got the book. When I got to Fred Meyer, I went around getting the food shopping done and saw at cookware section nearby so I headed that way. Well......lo and behold..
They had some Lodge Cast Iron Cookware on sale!
So, I picked up a 12" skillet, reg $24.95 for $14.95...a round 11 1/4" Grill Pan, reg $26.95 for $11.95...and a 7qt Dutch Oven with the Spiral Bail handle and iron cover, reg $67.95 for $39.95. I got a rain check for the Iron Grid/Griddle (16 3/4" x 7 3/4" cooking area), reg $49.95 for $29.95. Should be in next week. All are already seasoned...but I may give them another coat.
I am really excited about getting into (back into) cast iron cooking. Everything I've read sounds really fun, and I got some great recipes. I look forward to learning from you pros here too and sharing some of my experiences as I go along.
Greg
#6 ·
One thing I like to do on the weekends, is use the side burner on my BBQ grill and cook bacon/eggs with our CIS. Saves the kitchen from splatters and airborne grease.
#7 ·
Every time I see something about cast iron I spin backwards to over 28 years ago when I first got married. My dear wife and I received as a wedding gift a full set of cast iron cookware. Skillets (3 different sizes) pots (6 different sizes) 2 different sizes of dutch ovens and the wooden spoons and spatula's.
Well a week or so after we had settled in back home in our new home in the Philippines (Iwas stationed at Clark Field at the time) My wife decided to make her husband pancakes for breakfast, I was asleep when she started and I wake up to her swearing in Tagalog (the Filipinos language) I get up and walk to the kitchen and I burst out laughing. All over the kitchen is partial cooked batter on the floor, the ceiling, the counter, the stove and the sink. Seems my dear wife forgot one important fact about cast iron is You got to season it. I have teased her for the last 28 years about pancakes ever since. She will get so angry at me, but she knows it my way to tease her. All I ever have to say is pancakes.:bannana:
#8 ·
wingnut,
Thanks for cast iron 101. The facts and good advice never get old!
Cheers
JDFANATIC
JD2210
#9 ·
One can always find old cast iron cookware at garage sales, antique/junk stores and even Harbor Freight has a selection of cast iron cookware for a decent price.
One way we've cleaned old crusty cast iron is to place them in the fireplace for several hrs. Oh it does help to have a fire going at the time. The cast iron comes out looking like new but you do have to season the cooking surface again.
I use a cast iron skellet for the wood chips in the smoker, wonder if it make the food taste any better? Humm!
#10 ·
Have a friend who was quite particular about the treatment of his cast iron cookware. He did wash them with dish water. But always quickly, and the rinsed well, and put on the gas range at low fire to dry, then always wiped the cookware with olive oil. So maybe i should suggest that he not wash anymore? I will tell him about the salt and oil method.
#13 ·
We've been cooking in cast iron on and off for 36 years...we wash the skillet after each use and set it back on the range and light the burner and add oil, get it to where it just starts smoking and turn off and wipe down with a paper towel leaving a thin coating of oil in the pan. That skillet has been with us for 36 years and is no worse for the wear...wish I could say that about some of the other teflon wonders we have purchased over the years.
#15 ·
I treat my cast iron just like my wok...clean it with heat and keep it seasoned...Some of the best ribeyes I ever made were in a cast iron skillet...
season your steak however you like it...coat it with olive oil...
Put a 12" cast iron skillet in the oven...heat to 500 degrees...
Turn a stove top burner to high...
When the oven reaches 500 pull that hot skillet out, put it on the burner...
Sear the steak 30 seconds on each side then stick the skillet (with steak in it) back in the oven for 2 minutes...pull it, flip the steak and back in for 2 minutes...
pull it out, remove the steak to a plate to rest for 3 minutes and serve... OOOHHHLALALAA!!
Slam
#17 ·
No *****en in Diane's Kitchen!!
The pot rack I built! The seasond cast iron ware hung here (the bigger stuff kept elsewhere) BETTER NOT WASH PERIOD!!! Or the regrets will be hung on the ceiling along with other things!!
#18 ·
Well, this looks like the best place to put this so here goes.
Did anyone catch the Cowboy Challenge show on Food Network yesterday, Sun. This is the annual chuckwagon cookoff. I'm sure this will be rebroadcast again this week.
22 teams competing for the best chuckwagon grub. Virtually all the food was cooked in cast iron cookware and very high % of dutch ovens. In addition to the entertainment I'm sure some could find some pointers on cooking with dutch ovens over a wood fire.
One entry was from a Texan who's family has been ranching for more than 5 generations. Their chuckwagon was over a hundred yrs old and belonged to the entrants great grandfather.
You may want to take a look if this kind of cooking is of any interest.
#19 ·
I know alot of people swear by cast iron cookware, but I have not used much of it. I have a wide variety of cookware; some Farberware, but mostly industrial type cookware and some Calphalon.
There is some good info on www.foodtv.com on seasoning cast iron, and also explains why to do it, not just how to do it. Its almost scientific in a sense.
Greg
#21 ·
Greg
And how goes it?
I posted a thread this week on the subject not knowing this thread existed.
#22 ·
Edward said:
And how goes it?
Addressing Topics even if they have been address once before, new people new ideas :fing32:
Don't worry about threads that already exist, post your topic because its still Free :eek:mg:
#24 ·
Edward said:
thanks wingnut
am getting some sos pads today, going to use them and call it good. I hope I have not ruined one of the pots by taking part of the bowl down to bare shiny metal
Nothing just a whole lot of season to do, what I like to do for a bare shiny metal cook around 7 strips of beacon.
The beacon gease make a good base (you fusing pork potein to the pours in the iron, your doing the vegatable oil fusing a veg. protein)
Clean the with cooking vegatable oil and salt
Scrap out the residue beacon and salt with a wooden scraper
#25 ·
Edward... STOP! "... ---... pads" contain that awful ingredient "Soap"! Not good for CI. If you must wool, use a plain steel wool or brass wool (available at good woodworking suppy stores everywhere).
Bohicammer mentioned the wok and I can tell all that if you can't get to a wok almost any wokable dish can be made in a properly seasoned CI skillet... Providing of course that you're not limp wristed! :D You can't toss it that much but a wooden chan will stir all very nicely.
For both my 10" skillets, "Griswold" and "Sidney", handed down from my Gramma, I like the Fatte' du Swine method of seasoning. Bacon fat seems to be just the right viscosity at 300F. to take to the metal pores. These pans have never seen s-o-a-p since I wrested them from my Mother's grip 30 years ago. She (gulp) scoured them each time they were used until she bought some "modern no stick" cheap-0 teflonated aluminum pans.
"Say, Ma... What ever happened to the "Old Fashioned" cooking idea and can I have your old skillets?"
"Take 'em HydroHoneyBabyBoy, most everything I cook sticks to them... Good riddance!"
Well, somebody wasn't listening to "her Mother" 'cause I know Gramma seasoned her skillets as I used to "help" in the kitchen as a callow youth on the farm. One thing about seasoning is that if you use just hot water you won't lose much of the seasoning per wash and the very next meat dish you make will add more as you cook. It's a "whatever works for you" thing but CI is the coming trend in cooking. It's just that Ron Popiel hasn't found a way to market it by "TV infomercial" yet!
(Thank Heavens I didn't take after my Father and develop the dreaded "Kitchenophobia", I'da starved to death when I got married!) :D:D:ROF
#26 ·
Thanks HH
I finished cleaning them already, just last night. nice thing about SOS pads is they dont last long, they melt! So I took one, wetted a couple pans, lightly spread the sos soapy stuff on them then rubbed em down, rinsed and by the time I was thru the first pan the soap stuff on the sos was gone and then I did the next couple items... so all this to say I coud have used medium grade steel wool and been fine, and if I needed a scouring then I would have used bon ami. I dont mind starting from scratch considering I dont know the history of these items.
And I dont think that the previous owners seasoned them right if at all. On one or two items the black seasoning stayed in the casting dimples, and in some the steel wool cleaned it like new. Looked like no seasoning. And the one that didnt come shiny new was the Lodge brand and someone mentioned they season them at the mfg.
So today I bake them in the oven. I would use the grill but its not as easy to regulate the heat.
