Trying to return the brush blade to service. Can't seem to lock the shaft to tighten the nut. Gravely (L?) in gear (F+R), deck in gear, even out of gear just to see. To be certain the trans worked, I tried rolling by hand it and yes indeed when in gear it won't roll.
Contemplated pulling the big plug on top and jamming a chisel into something to stop the rotation. Didn't want to open a can of worms that had nothing to do with current issue. One at a time please.
I'm used to Stihl equipment that has a hole and shaft system to stop rotation when doing an install. I did notice a small hole and plug on the side that looked attractive but I didn't investigate for fear of making bigger problem. If I remember, it's opposite the grease fitting on the swivel casting. Looks to be a threaded 1/4 hole and plug.
Looking at the schematic, can/should I put my large waterpump pliers on the Keywayed Fixed Collar and then just reef on it?
BTW is there a Torque Spec for the blade nut?
Do I have to take the deck off the tractor?
Came here, I thought I'd seen this issue go by before so I searched for it but no dice.
Feeling pretty stupid, exasperated and, getting a bit grumpy too. I'm even willing to listen to reason for a change.
If you have a moment I'd appreciate getting smartened-up, please.
TIA
Mark
TIA
Mark
