Simplicity Prestige, bought it 1 month ago, was still in the crate brand new.
2023 Prestige 27 / 52"
SCS 2691678
Prestige™ Garden Tractor
The first day it was delivered as I was getting use to it driving around the property, there was one time it just shut off for no reason. I restarted and everything was fine I didn't think anything more about it. The following days this continued to happen at different times, it didn't matter if the blades were spinning (PTO engaged) or I was just driving without blades turning. It's been a few weeks now, and I've tried to note every possible indication - but it just seems random. I sure don't like it when it happens while I am mowing up a steeper incline and it does it.
I'm pretty handy so I've checked every single connection, even while it was running to see if some connection was intermittent, but nope. Voltage from battery reads about 13v when the unit is off and 15v when it's running. It's just as if I pushed the electronic start button to off. No engine sound changes before to give indication, it just plain shuts off.
It's not the gas cap vapor build up either, I had the cap totally loose to check that, and still does it.
There were a few times I was mowing for an hour and it worked fine, then as I pull up to the garage sitting there while it's idling it just shuts off. Or if after using it for a while and turn it off, and when I start it again, sometimes it will turn off in about 10 seconds ..I'll start it again, 10 seconds (aprox) later shuts off again, it can do this a few times, but then when I start again it can work fine for a long while afterwards. It's intermittent in every sense of the word.
Yes it's under warranty but I have no truck, so it's almost $100 transportation round trip to/from house/shop/house/and back - Besides I'd rather get to know it and fix it myself, if I can.
SCS 2691678
