I'm still looking for a garden tractor and stumbled upon the following sale.
Let me know what you guys think.
Is this already set up to accept implements and what implements would be compatible with this GT?
1978 Wheel Horse D 250 4 Cyl. Renault Compact Garden Tractor - $1750
"This is a 1978 Wheel horse D250 made in Germany by Gutbrod. I bought this off the original owner 3 years ago. I have used it ever since just for mowing. The engine is a four cylinder Renault which starts with ease and has 808 hours on it, but will have more by the time it sells because I am still using it. The valves were adjusted to factory specs. at .006" Intake and .008" exhaust about 50 hours ago, oil changed 5 hours ago. Tractor had a coolant flush, new rear end grease, new hydro lift hose, new cap and rotor, spark plugs, new front pto bearings, and new front pto belts last year. All lights work, tires hold air. The transmission shifts in to all gears hi-lo, differential lock, parking brake, and rear pto all work great. The steering has a little looseness but is normal. The seat has no cracks or rips and is soft but does have three rivets on the trim edge to keep it on the seat pan. None of the wiring has been spliced. As far as i can see this tractor has never been tinkered with. The deck is very solid with new spindle bearings, idler pulleys, and gear box grease this spring. Deck is 60" cut, is very quiet, and cuts nice and flat. The rear fender is plastic and has been repainted along with the deck and lower grill piece"
"There is nothing wrong with this tractor the only reason i'm selling it is because i'm cleaning out my garages and this is taking up to much room"
"Make Offers"
"Make Offers"
