It’s been one thing after another with my 26 year old LX this year. Got the fuel issue fixed thanks to Cannon51. Then the plastic hood hinge broke off...used bondex to repair that. Yes I know it will probably not be a lasting repair but it works for now. So now the battery light started staying on. This issue may have started when I forgot to reattach the headlight wires. They were dangling under the tractor still attached to the heat shield and I forgot about them and drug the heat shield about 15 feet in reverse before I noticed. So maybe I loosened a connection somewhere.
The battery tests at 12.46 volts when off and 14.06 volts when running. If connections seem okay would this more likely be the voltage regulator, or possible the flywheel alternator. I don’t have a shop manual so not even sure if there is a fuse involved. Any thoughts on how to best approach this would be appreciated.
