Where is the compression release on JD LX 172?
You probably wouldn't have to research it if you posted the make and model number of the engine. No mind readers here.Thanks I figured but wasn't really sure. That's something I'll have to research.
LX172 uses a Kawasaki FC420V. It does have a compression release mechanism on the cam (see below).Not sure which engine your tractor has but most are on the camshaft. Roger
