Not for the "V" engines. They used a Champion RJ12C. The DuraForce and "V" series were the only Lawn-Boy engines (to the best of my knowledge) that used a different plug than a CJ14. They're gapped at 0.030", not 0.035" like the OMC D-600, "M", and "F" engines.
Interestingly, my boss' 10545 ("F" engine) came with an NGK plug BMR4A, which is a direct cross to a Champion CJ14.
I knew the DuraForce uses an NGK plug, but that one is unique to that engine...It has an extended tip, and there is no perfect cross into Champion for it. NGK BPMR4A crosses to a Champion RCJ8Y, but that plug is several steps colder, though it is of the same design.
I had never seen an "F" engine sporting a factory-installed NGK plug before. I wonder when/why the switchover?
Edit: I think I figured it out...Champion doesn't make a resistor-type CJ14 (RCJ14 would be the part number if it existed, but it doesn't), and possibly they were required to use reisitor plugs in all their engines, so the resistor NGK equivalent was the only logical choice.
