Howdy All,
I got a 44 Snowblower with a new-to-me x320 this week. Clearly I should have looked closer at it... It was in a shed and the shiny paint caused me to make assumptions rather than checking on things. My bad.
First the up/down deflector control is stuck. I can rotate it 180 degrees to lock/unlock (presumedly) but it has no travel in and out. If I try much harder I'm going to break the plastic handle. My plan is to remove it, hang it up, and drip oil through it for a couple days and try again. It's a $50+ part so I'd like to salvage this if I can. Other advice welcome.
Also, one of the auger blades is bent pretty severely. They still rotate. My current plan is to get a shim in there and use a 2x4 to bend it back in small moves, but again - any other advice is welcome.
Peace,
Phil
Peace,
Phil
