I bought a JD 317 with blade to use for snow removal. The engine blew ( I guess it threw a rod -- I'm not much of a mechanic, but there is now a hole in the side of the engine block). I realize this will make vintage tractor lovers cringe, but I went cheap and practical and mounted a Predator 459 engine in its place. I got it lined up, bolted in, and turning the shaft just fine. The problem is that it now won't engage the power to the rear wheels. I took the back body off, and cleaned up the two buttons that the disengage knob touches, so they move freely. At this point, there is a faint whirring sound when slide the lever for forward or reverse, but movement.
I'm hoping someone can diagnose and/or give an idea of next steps. Everything was working fine for an few hours I would spend few hundred at a mechanic shop if I had reason to think it was fixable at a decent cost. It doesn't seem like it should go to the scrap yard, yet, but......
