Does anyone have a Idea of remove the Brake Disk on a MTD990????????
You're right - it could be something inside the transaxle, but by the exploded view in the MTD 990 manual, it's very hard to tell just exactly where the parking brake connects. I'm going to clean up the disk enough to see if there's a key or not. If not, I'll get the disk loose, take it off and clean it well. Then I'll replace everything, including a new key, and see if it works like it's supposed to. If not - the search continues.I'm wondering what is on the other side of the brake's shaft that could be slipping. Could be a sheared pin or key there. The disk spinning on the shaft outside is a sheared key there.. If not--- It's inside the transaxle..
Sorry I tried to help..
Scott,Heres a pic, looks just like yours, but with a sleeve and some addition mods to the Caliper pull set up, this thing works perfect.
Scott
