So end of last season I picked up a used 2014 Gravely Proturn 260 with Kawasaki fuel injected motor. Only used it one time before putting it away. But the former owner had put a new battery in it. I used it the other day and I shut off the PTO to pick something up in the yard and then the PTO would not engage again. I ran into this when I worked as a landscaper using the same mower. Battery was getting low. Charged it and it worked fine rest of the day. Just figured it was due to sitting all winter. Ran it again today, and it was fine until the end of the mowing (I mow over 2 1/2 acres) and the PTO would not engage again. Check battery and its low again. When I have it running, I get 14.5 volts at the battery. When its off, and battery is charges, its at 12.3-12.6 volts.
What should the volts be at the voltage regulator? I tested it, but forgot the numbers. Have to recheck again tomorrow after work.
Anything else to look for? I did check both fuses that are under the seat and they are fine.
Also I have to remove and replace the seat safety switch. How the heck do you get it out without tearing the seat apart?
