I went to clean the points on my 3415 today to try and figure out why I have no spark and when I took the points cover off there was nothing there! At least I think this is where the points should be, correct me if I'm wrong. I also took a pic of what I think is a voltage regulator that he had bolted to the side of the tractor, I'm not sure if this is factory or not? He also has a toggle switch on the dash that you have to turn on to get spark. I'm just trying to get the electric sorted out so I can put this thing to use finally. If anything I would just like to return everything back to the way it's supposed to be. Anyways, take a look at these pics I took and let me know what you think is going on here...
