Cub Cadet SLT 1554 54" Deck
1 reading
7.4K views 4 replies 3 participants last post by  Skyhorse76
#1 ·
Hello, I have a Cub Cadet SLT 1554 with a 54 inch deck. I changed out the blades on it Yesterday and noticed the belt was getting bad. The manual I have calls for a number 754-04083. When I search for this belt I can find it on several sites. I am confused because some sites list it as a 136 inch belt and others list it at a 138 inch belt. Does anyone here know the correct size? Thanks in Advance...
#3 ·
Skyhorse, I’m not sure what your part number is for but on the Cub Cadet parts site I looked on it shows 3 different SLT-1554 listings. 1 with a Command engine and 2 with the Courage engine. The separation beween those 2 is 2007 and older and 2008 and newer. Interestingly all 3 listings show the mower deck belt as 954-0642. I’ve used V-Belt Supply numerous times for Cub Cadet belts with great results but wherever you get your belt it would appear that the 954-0642 is the belt you need. I have a 2006 SLT-1554 with Courage engine and I use the 954-0642 belt. Good luck.
#5 ·
Hi Merlin 2014, Thank You for replying. My Cub Cadet falls in this group
CUB CADET PARTS DIAGRAMS, CUB CADET SLT1554 TRACTOR COMMAND ENGINE 13AK11CK709 13AK11CK710 13AK11CK712. It is the 13AK11CK709. When googled you get the Cub Cadet site and it gives you the belt size 954-0642. So I ordered this belt size and will find out. Thanks Again..
