Bagger from X475 fit on a GX345???
6.9K views 14 replies 6 participants last post by  TJR345
#1 ·
Hello -
I am looking at buying a 3-bag bagger that was on a X475 to put on my GX345. I just want to make sure the rear mount will work on my GX. I'm assuming the chute will be interchangeable with the current powerflow that I have on mine just want to make sure before I buy it. Any help is appreciated.
Thanks!
#3 ·
Much different set up....the x495 has what is called a click n go bracket to attach the bracket on an x475.....your Gx345 will not be like that.
Sent from my SM-G900V using Tapatalk
#4 ·
I agree...not to mention the deck size would need to be the same for the power flow.
#5 ·
Deck size will be the same, both 54". By looking at pictures i'm confident that at least the chute will match up to my current powerflow. Or at least because the decks are the same size, the powerflows will likely by identical. Either way i'm curious about how it connects to the back of the tractor? My current 2-bag just slides in, pin on each side and a pin on the bottom in the hitch. How different is the connection with the 3-bag system? Can I purchase the click n go bracket to make it work on my GX345? or will I have to make a custom bracket. Its a pretty good deal that I don't want to pass up. Thanks!
#8 · (Edited)
What you posted is for X500, X530, X540 etc tractors.............Not X475, X485, X495, X575, X585 and X595 like the power flow you are looking to use on your GX345.
Not sure if this will work or not.............Part # 15 is that part number you listed.
John Deere - Parts Catalog
#7 · (Edited)
The silver lever and black metal part( is the click N go brackets) is what the bagger bracket slides into.
#11 ·
Definitely won't fit unless you make up your own mounting brackets. I have a 2 bin bagger on my GX345 and it is way different how it mounts compared to a x475. See picture that I attached.
#12 ·
#14 ·
I think the pictures of what you are buying is what we really need to see to help you know if maybe it will work for you or not.
#15 ·
The 2 and 3 bag hoppers are all the same.The lower part of the mounting bracket is what is different between models. Below the hopper top is 2 bolts which exchanges the mounting frames.
