I have a 54'' blade on my 316 and this past weekend I broke 2 90 degree fittings off the same line. In this pic it is the rear most line on top.
When the blade is up that top rear set of fittings is real close to my frame/cross member and if I push with it it rises more and cracks the 90. I guess you're not supposed to push with the blade up but I can't seem to get away from that. That top rear most line has also mashed a big old dent in the frame, thats how hard it is hitting.
I am going to spin the ram so the lines are on the bottom of the cylinder to try to avoid this in the future. With a few 45 degree fittings this seems like it will work, we will see tomorrow. Has anyone else ran into this problem and how did you take care of it?
thanks
thanks
