Hi everybody. I recently decided to fix up my late grandpas 2 JD mowers a 185 hydro 46 inch deck with the 17hp kawi and a 175 with 2 38 inch decks and a 14 hp kawi. Ive got the 185 coming together pretty good except for a couple issues maybe yall can help me with. 1= Does anyone have a picture of how the front of the deck attaches to the frame? It was off when I got it and im sure im missing a bracket or something. 2= Is there anywhere other than the dealer to get new deck spindles for the 46 inch deck? 3 @ 155 each is gonna get pretty expensive quick. 3= On the carb above the line that feeds the fuel there are two nipple looking pieces one with a hole and one without the one between the linkage and the block has had a piece of hose put on it and blocked off. If you remove it gas comes out while its running and drips on the sheet metal. Does anyone know what that is and what it needs to be hooked to instead of just blocked off? Thanks a lot Im now gonna attempt to load pics of the carb. Wish me luck.
