Synthetic oil does not have any additional cleaners or detergents in it than regular oil of the same grading. It will not remove any sludge that a conventional oil would not remove. You can mix synthetic with regular oils (semi-synthetic), you can go from syn to regular and back to syn . Synthetic oils have a man made base as opposed to crude base and does not break down as quickly as well as maintains its viscosity better in all heat ranges. The only thing that syn will do is have a tendancy to leak past a worn seal easier than regular crude stock oils. The only thing I have seen a syn oil do in such applications as maybe a motorcycle where oil lubricates a clutch as well is for a clutch to possibly slip due to its better lubricating abilities. In a hydro there are no friction clutches to affect. An eaton 11 recommends 20w oil that is designed for no wet clutches so motor oil is fine.
