1 - 19 of 19 Posts
breakin the bead is the hardest part, theres many methods to do this depending on what you have available. then its just amatter of working the beads over the edge of the rim. really its pretty simple. p.s. thats the short version, ask if you want details.
A 12" wheel will fit a tire machine, but it's pushing it. I know my Coats 10-10 had trouble pushing against the bead itself. There was juat a post showing alever and a block of wood that seemed like it would work very well.
From what I understand those HF tire changers are pretty slikc for the cost. They are really nice for small tires like tractors have. To install the tires on the front rims of my Massey, I had to bolt them to my work bench!
I have been changing tires in my shop for almost 30 years now,And have all the equipment to do so.If you don't have the know how or tools needed to do so,then your better off going to a tire shop.
maybe you should at least try it. you wont be out anything if its not your cup of tea. and you may suprise yourself and save 30bucks.
I have been eye balling one of those tire changer/bead breaker on harborfreight.com? I think it would be a handy little tool for the do it yourselfer.
I have one:
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=34542
It's $60, but goes on sale all the time for $40. It's one of the best $40 I ever spent. I've used it all of a dozen times, but it paid for itself after the second. It's been used mostly for ATVs, but I used it once to put tubes into the front tires of my big Kubota, which have standard 15" tubeless automotive rims. I expected the Kubota rims to give me grief, but they were a piece of cake. I use it exclusively as a bead-breaker - it has some provision for mounting a rim and pulling a bead on-off, but I can't figure out how that works. I just grab a couple of tire spoons and changing the tire takes about 10 seconds (ATV and car tires are sooooo much easier than dirtbike tires, let me tell you).
I don't have it bolted to the floor - if you have the space to permanently mount it, it would be great.
JayC
Someone either on this site or one of the others I visit had posted about using the mini changer from HF. http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=34552
They welded the base to a bar that fit into their receiver hitch on the truck and made a nice solid working attachment. The larger tire changer posted here looks a lot beefier, but the mini changer should handle the needs for most all L&G tractors and ATV's.
I have one each and the sure are slick.
This one for the smaller front wheels:
This one is for the bigger rears:
I changed and tubed all my tires. The 4 ply rears went one easy as pie but the 6 ply fronts, well they put up a little fight but after a little persuading, they gave in.:ROF You can see both of the changers in the first picture and then the larger one being put to use in the second picture. Great little items and worth the investment IMHO. Now I don't have to worry about trying to make it to the tire shop.
1 - 19 of 19 Posts
