1 - 8 of 8 Posts
TJR345
Is there a place that has a list or listing of attachments that fit the X595, or what is compatible for this and other X-series tractors.I was just looking to see what was and is available.
Discussion starter · #3 ·
Basically anything that fits X4xx and X7xx series machines.
Thanks,I was looking at some stuff on CL and don't want to shell out money on something that won't fit.
I have read somewhere that the term "Limited Cat 1" defines the implements that we can use. The GT 3PH cannot pick some implements high enough.
I'm not sure that this is correct or even if it addresses your question but it may get some answers flowing.:dunno:
any of the quick hitch snowblowers and snow throwers will work. Just need the correct shaft for your application. If you are looking for the front quick hitch, the one for the X series has a bar across the top and goes in the two goal post looking things on the front bumper. A quick hitch from a 4x5 series will work as well, but the bar goes on the bottom where it hooks into the mounts for the mower. You will need longer hoses and 90 degree fittings for the ends as well to since the valve is in a different location between tractors.
Good luck
Adam
Good luck
Adam
So the older quick hitch hooks up different then the newer style,but either one will work.Do the newer ones have the lift and angle.
1 - 8 of 8 Posts
