THought this was kind of a neat wheel barrow gadget
Here
Here
The correct term is wheelbarrow.so what is it a wheel barrell or a wheel barrow? the last post was obviously a wheel barrell
Looked to be a 55 gallon wheel barrel. Or is it 27 1/2 gallon?
That would be fifty-five of those tiny US gallons instead of 45 of Her Majesty's Regal gallons you and I are used to. :sidelaughIs that US gallons or imperial. :hide:
No........ it would be called a "wheelessbarrow" at that point. :sidelaughIf you took the wheel off, would it be called a barrow??
I found this on Google.No........ it would be called a "wheelessbarrow" at that point. :sidelaugh
2 workers instead of one? More union featherbedding...!Hand Barrows
A hand barrow is a wheel-less box or stretcher with handles on either end. They are illustrated used in building construction, and by miners to remove material from the mines and for washing the ore. The hand barrow has the distinct advantage of not requiring a wheel and therefore being relatively easy to construct, but the disadvantage of needing two people with relatively strong backs.
