Hey guys, this machine been the biggest pain! We got it after another guy took me and the "loose bolts" turned out to be a blown original engine. We found a 170 engine and got it in. This engine sat in junkyard for a while and had some issues with stuck exhaust valve and such. You all may remember my numerous posts on it. This month was not my best so far, a lot of personal issues. Thought I got this starting issue licked. It would backfire through carb and finally fire, choke seemed of no use. We swapped the igniter and coil out and cleaned carb three times, with Sea-foam through system. It acted better with warmer weather. It is back to hard start, and noticed a lot of blow-by. Any ideas where I should go next ,other than a bonfire!? Dad and neighbor spent over an hour using plasma cutter and hammer to get rr tire/wheel off that was frozen on. Thought we would at least get it done for the neighbor!
This one ,I thought the gas was out, it still had enough.
