Hi; I'm coming to the forum w a few Qs re the used 755 4WD w BH and FEL I just bought; It has ag tires and I want to go to turf. After extensive research some of which like in tractordata.com is way incorrect acc to a yard that has 7 of the 755s and also the local dealer. Both said U have to match the 33x12.50-15 Rr to a 23x8.50-12 F to keep 4WD ratios correct. The other available 31' Rr size used a different F size (25x8.50-14 not the size tractor data.com says) I want to know why I shouldn't go to a wider tire like a 9.50 or 10.50 on the front(12x7" rims) if I keep the 23" height[for correct ratios using the stated 33" Rr size to match] I'd like the extra support on the kinda heavy front end on a lawn w low soft spots. Q is will it be a lot harder to turn or something undesirable? 2nd Q Local Kubota sales rep was a JD service manager for 20+ yrs and knows the 755 well. Said the frame was never really meant to have that much weight F and Rr (w FEL and BH) and hitting a bump in a field going too fast could actually break the frame in half. I looked at tons of these and saw v few with a BH. Most had FELs and often mowers. Anyone ever heard of this prob w the frame? I'm an old bodyman and was thinking of reinforcing it. On rusted car frames we used to call it "fish plating" or some such. I tried to find a tire change thread to answer me w/o success Thx Gus
