Re: What did you do to/with your Gravely today?
hello. peps on mtf. i have a lil problem and need some help. i have a 54 gravely LI that is giving me problems. i think its over heating ive cleaned the carb and replaced the spark plug point and condenser . i think the timing is off. i restored it this past winter. it ran great for severl months. and now i can use it for about an hour and it will slowly start to slow down and then stop. i adjust the fuel mixture and everthing while its running with no luck. i used stainless steel head bolts and i noticed today that the ones on the exhaust side are starting to get a rainbow look to them. what do i do. thanks
Don't worry about the head bolts changing color, the Exhaust side if the Gravely T-Head engine gets Very hot.
The timing will not change over a few months, as log as you set it correctly this first time all should be good. You may want to check the following...
1- tightness and and or serviceability of the fan belt, if you have a governor DO NOT use it as a fan belt tensioner, adjust the fan up or down to adjust and or remove the belt.
2- is the fan turning when the engine is running?
3- are ALL the cylinder and head cooling fins clear and clean of dirt and debris?
3- often times people do not install and or remove the metal surrounding the cylinder, this metal, or cooling tin, directs cooling air around the cylinder and head and allow for better more efficient cooling. If you plan on using this tractor a lot and there is no cooling
tin installed I would suggest getting some.
4- air cleaner for serviceability
5- proper oil level
Also the main gravely board is a much better place to post these types of questions as more people will see it, this is a page located in the sticky section, so not everyone will see it.
Good luck!
Corey
The attached photo is of my early 50's L, notice the cooling tin on the head and around the cylinders. I use this tractor weekly with a 40" mower deck to cut 1.5 acres. I've set this tractor up for best performance, among other modifications I've advanced the timing a bit more than standard, I've never had any issues with loss of power throughout 2-3 hours of solid running.
Sent from the MTF Free App
