Just bought a used bx2660.
Everything is great except ...
Forward works fine.
Reverse is intermittently jerky when releasing the reverse pedal.
Sometimes it stops okay.
Other times , it slows down okay, but just when ready to stop, it jerks to a halt.
Also, at times it will slow down very quickly and jerk to a halt.
Did some research before buying and thought this problem was fixed on the bx**60 series.
changed the trans fluid and filter and cleaned the strainer.
greased the pedal fitting and tried adjusting the neutral return spring.
no help
I also moved the speed foot pedals forward and reverse with the tractor off and nothing seems to be binding. Both forward and reverse return fine with tractor off.
Could it be the HST damper?
I have run out of ideas
Anybody help???
thanks
Forward works fine.
no help
Anybody help???
thanks
